First, here is a link that shows the routing for your vehicle. Check it to make sure you have it routed correctly.
https://www.2carpros.com/diagrams/acura/mdx/2001
If it is routed correctly, with the belt off, check to make sure all pulleys turn and there is no excessive play in them.
If they check good, next, install the belt and determine if all pulleys align.
One of the aforementioned checks is causing the problem. Check those things and let me know what you find.
Sep 18, 2018 at 5:31 PM
