Replacing serpentine belt
2017 HYUNDAI SONATA
106,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TERRI SPERR
Need a diagram for the vehicle listed above SE model.
Sep 10, 2020 at 7:51 AM
STEVE W.
  • 15,113 POSTS
There are two belts on that engine if the data is correct. One is a stretch type belt that powers the water pump only. That is the first image, the other belt powers the alternator and A/C compressor and uses a tensioner. That is the second image. It wraps around the crank pulley and under the A/C clutch then up to the alternator and then back to the crank pulley. The tensioner needs to be moved counter clockwise to remove or install that belt.
Sep 10, 2020 at 10:52 AM
