replacing power window motor in rear door of 1995 Saturn SL2
1995 SATURN SL2
108,000 MILES
BUNGERAL
I have removed the door skin and trim but do not know how to remove the glass and get at the motor to replace it. Or, is there a way to manually get the window back to the up position? If there is a way to manual get the window back up that would suffice for now. Is there any manual available that shows how to do this work?
Sep 19, 2013 at 7:19 PM
SATURNTECH9
  • 30,869 POSTS
Those motors are direct drive to the regulator hear to gear.Also the motor is riveted onto the regulator.So the glass has to come off.The window nuts need a special tool.If its not used there is a good chance you could break the glass.The nuts are usually pretty tight and a lot of the time they use loctite.They sell the tool online if you need help finding one.
Sep 19, 2013 at 8:04 PM
