Replacing Power Window Motor?
2002 LINCOLN CONTINENTAL
153,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
RCHMNDNY
  • 5 POSTS
Can anyone tell me if there is a way to replace the Rear Passenger side power window motor without removing the regulator assembly on the car listed above?
Jun 13, 2025 at 7:18 AM
Nope, you must remove the regulator and then the motor, be warned when you remove the motor it will release the helper spring which has some leverage and can cause injury so be ready. I used to use vise grips on the regulator to stop the spring action while the motor is being swapped out. You will also need a large pop rivet tool you can use for your installation. You can rent one for free at the auto parts store.
Jun 13, 2025 at 11:45 AM
RCHMNDNY
  • 5 POSTS
Ken, I just learned that if I drill these 3 dimples in the door that I circled on the attached photo in black, this will give me access to the 3 bolts to remove the motor, and the regulator will be left installed on the door.
Do you know if by removing the motor this way, the helper spring you mentioned will still release, or will it stay in place since the regulator is still attached to the door?
Thank you for your help.
Jun 16, 2025 at 8:01 AM
Hmm, I have never replaced the window motor before this way. If the frame of the regulator stays bolted in, then you don't need to worry about the helper spring.
Jun 16, 2025 at 10:14 AM
RCHMNDNY
  • 5 POSTS
I will update you when I finish, if it ever stops raining. Thank you for letting me know about the helper spring. I will be mindful of this while replacing the motor. You saved me from losing a finger or worse.
Jun 16, 2025 at 11:17 AM
No problem, that is what we are here for, I wish we could get some rain :/ maybe you can send some our way?
Jun 16, 2025 at 11:23 AM
RCHMNDNY
  • 5 POSTS
You were right, everything needs to be removed. Lincoln attached the motor wire to the regulator. The wire can only be removed and attached with the regulator out.
Jun 19, 2025 at 10:15 AM
Yep, I never heard of doing the job the way you suggested but you never know until you try. Did it have the helper spring and did it go back together okay?
Jun 19, 2025 at 10:32 AM
RCHMNDNY
  • 5 POSTS
Yes, thank you for your help.
Jun 19, 2025 at 10:45 AM
You are welcome, please use 2CarPros anytime we are here to help.
Jun 20, 2025 at 10:23 AM
