Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Mercedes Benz
C300
Body
Window
Switch
Replace/Remove
Replacing master window switch
2017 MERCEDES BENZ C300
76,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
DIVIDES
MEMBER
FOLLOW
Can you find out for me if this master switch can be removed without removing the door panel? Also, the lock/unlock button.
May 7, 2022 at 4:23 PM
SQM
CERTIFIED EXPERT
I have attached the procedure below for the switch removal. It appears that you will need to remove part of the panel in order to remove the switch.
Let me know of any questions.
Thank you.
May 7, 2022 at 8:47 PM
