Good evening,
You will need:
1. lug wrench for the wheel.
2. 6-inch long screwdriver.
3. Set of torx sockets for removing the caliper pins for the brakes.
4. Hammer. You will need a good size one to knock the rotor loose.
5. A 30mm or 32mm socket for the axle nut. You will need either a 1/2 air gun or an electric gun to release the nut.
6. 8mm and a 10mm socket for the ABS sensor.
7. Either a 13mm or 15mm socket with a ratchet to release the bolts holding the hub to the spindle.
https://www.youtube.com/watch?v=vf-Z3sm-4UM
Oct 5, 2019 at 3:08 PM
