does the water pump need to come off for this job ????
Aug 17, 2019 at 12:31 PM
CERTIFIED EXPERT
Good afternoon.
In order to remove the seal, the front timing cover has to be removed.
Yes, the water pump has to be removed.
The belts have to come off, the crank pulleys have to come off, the harmonic balancer has to be removed and the water pump before the cover will come off.
Aug 17, 2019 at 1:25 PM
BROOKS BONNIWELL
MEMBER
thank you very much for the information. it will just take a little longer to do.
Aug 18, 2019 at 12:51 PM
BROOKS BONNIWELL
MEMBER
i have no problem. i just would like to know what oil seal you would recommend?
Aug 20, 2019 at 9:51 AM
(Merged)
CERTIFIED EXPERT
Good evening.
Either Timken or AC Delco. They are both good seals.
