Replacing evaporator core?
2007 SATURN ION
173,500 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JACOBWA1992
Will I have to remove the dashboard to pull the hvac housing out? Or can I remove and replace the evaporator core by removing just parts of the middle console that are in the way?
Feb 8, 2026 at 10:39 AM
STEVE W.
  • 15,113 POSTS
The dash has to dome out, then you pull the HVAC housing. From there you split the housing and remove the lower shell and then you can get to the cores. No way to do it with the housing in the car. Wish there were but there isn't because of the way it's designed.
Feb 8, 2026 at 1:43 PM
JACOBWA1992
Ok, thank you Steve. Do you happen to know anywhere I could look at a step by step for the entire process?
Feb 8, 2026 at 3:05 PM
STEVE W.
  • 15,113 POSTS
The easiest way is to get a limited DIY subscription from Alldata or Mitchell. You then have access to the same info as a shop for the time you selected. BUT it's also not hard to start at the top and print the data to .pdf files for use later
https://www.alldata.com/diy-us/en or https://eautorepair.net/
Look over their examples and then start printing the info out. The advantage of that is that I'm used to doing the job and might miss a step that is in the book.
Feb 9, 2026 at 2:06 PM
