Replacing these mounts on a friend's truck, 4x4.. My main concern is the rear one. Also, how would you suggest replacing them all without putting stress on others,e.g. changing the top passenger one first then front radiator one, then moving to other side, while jacking up the motor. if the new ones are tight there should be stress on them.. maybe use one of those Harbor Freight engine support to make sure all are installed at same time with very little stress and give me more room?
Aug 17, 2020 at 5:51 AM
