Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Infiniti
G20
Engine
Serpentine Belt
Replace/Remove
Replacing drive belts
1995 INFINITI G20
288,000 MILES
CNESPOSITO
MEMBER
FOLLOW
Having trouble getting drive belts on.
Jan 26, 2019 at 4:46 PM
CERTIFIED EXPERT
Good evening,
What kind of trouble?
https://www.2carpros.com/articles/how-a-serpentine-belt-works
Are they too short, too wide or cannot get it over a pulley?
I attached a diagram for you and if you will tell me which belt, I can continue to help.
Image (Click to enlarge)
Jan 26, 2019 at 5:36 PM
CNESPOSITO
MEMBER
Thank you for the diagram which also shows what needs to be loosened! Got the old belt off, getting the new one to not have so much tension.
Jan 26, 2019 at 8:54 PM
CERTIFIED EXPERT
It may be the incorrect belt. It may be too long and need a shorter belt.
Jan 27, 2019 at 4:11 AM
CNESPOSITO
MEMBER
It's too tight, not too loose. Which bolt do you loosen? Top, bottom or both?
Jan 27, 2019 at 6:29 AM
CERTIFIED EXPERT
Both in order to allow the adjuster to swivel. Then tighten both bolts.
Jan 27, 2019 at 6:30 AM
