Replacing Cooling Fan Assembly on 2006 Saturn Vue V6
2006 SATURN VUE
128,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
THEALIAS
  • 5 POSTS
Looking for instructions on replacing the cooling fan assembly on my 2006 Saturn Vue (V6). Two different mechanics said that it needs replaced. One stating it draws too much power and the other saying it was sticking. I've had the wire from the 3rd relay and the relay itself replaced (as well as the plug) because I was told they were all bad. Any assistance would be greatly appreciated.
Jun 25, 2014 at 12:23 PM
SATURNTECH9
  • 30,869 POSTS
I have replaced one fan assembly on those in my long time of working for saturn.On those you have to remove the front bumper skin and tilt the ac condenser and radiator to remove and replace the fan.I will see what I can find on instructions.
Jun 25, 2014 at 12:52 PM
THEALIAS
  • 5 POSTS
Thank you saturntech9
Jun 25, 2014 at 9:04 PM
SATURNTECH9
  • 30,869 POSTS
there you go I don't remember having to drain the coolant if you have to drain the coolant don't use the radiator drain,I have had several come back leaking from the drain after using the drain.Use the lower radiator hose to drain the radiator,
Jun 25, 2014 at 11:05 PM
THEALIAS
  • 5 POSTS
Replaced fan without any issues. Thanks again for your help.
Jun 27, 2014 at 5:19 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome glad I could help you out thats what were here for. So did you end up having to drain the coolant after all?
Jun 27, 2014 at 12:41 PM
GREGORYJH
Can I get a copy of this procedure?
Aug 28, 2015 at 9:01 AM
SATURNTECH9
  • 30,869 POSTS
The instructions are three posted replies above yours.
Aug 28, 2015 at 1:04 PM
