Trying to remove the brake caliper?
2014 BMW X1
75,000 MILES • 4WD • AUTOMATIC
ALEXISJENSEN
Trying to remove the brake caliper so I can replace the brake pads?
Jun 14, 2019 at 5:14 PM
Good morning,
I attached the procedure for removing the caliper for you.
I also attached a guide for replace the pads and rotors as well.
Repair instruction
Removing and installing or replacing front left or right brake caliper (Teves)
34 11 020 | REP-REP-RAE8734-3411020TEVES - V.6
34 11 020 Removing and installing or replacing front left or right brake caliper (Teves)
Important!
The brake pad wear sensor must be replaced once it has been removed (brake pad wear sensor loses its retention capability in the brake pad).
Necessary preliminary tasks:
Remove wheels.
Read and comply with General Information.
After completing work: Bleed braking system
Press brake pedal down to floor and secure with pedal support.
Note:
The pedal support may only be released when the brake lines are reconnected.
This prevents brake fluid from emerging from the expansion tank and air from entering the system when the brake lines are opened.
If necessary, pull brake hose out of holder (1).
Important!
Grip brake hose at square head (3) to prevent connecting piece from turning in retaining bracket.
Disconnect brake hose from brake line (2).
Installation note:
Tightening torque:
34 32 1AZ Type Thread Tightening specification Measure
1AZ
Brake line screws /
union screws
E81, E82, E87, E88, E90, E91, E92, E93, M3, E84 M12 x 1 12 Nm
M3
Blue union screw connection in steel e.g. brake hose
17 Nm
Detach brake hose from brake caliper (4).
Installation note:
Tightening torque:
34 32 2AZ Type Thread Tightening specification Measure
2AZ
Brake hose to brake caliper, front
E81, E82, E87, E88, E90, E91, E92, E93, E84 24 ± 2 Nm
Important!
Never twist brake hose when installing it and avoid all contact with parts attached rigidly to the body.
Note:
First tighten brake hose on brake caliper.
Move wheels into straight-ahead position.
Insert brake hose in bracket and screw onto brake pipe.
Unscrew guide bolts (1).
Remove brake caliper by pulling upwards.
Installation note:
Clean guide screws only; do not grease.
Check threads.
Replace all guide screws which are not in perfect condition.
Tightening torque:
34 11 4AZ Type Thread Tightening specifications Value
4AZ
Guide screw (socket head cap screw)
E81, E82, E87, E88, E90, E91, E92, E93, E84 WAF 7
Replace self-locking or microencapsulated screws
30 Nm
Repair instruction
Removing and installing/replacing both front brake discs
34 11 220 | REP-REP-RAE8734-3411220 - V.7
34 11 220 Removing and installing/replacing both front brake discs
Special tools required:
34 1 280
Remove wheels.
Remove and clean brake pads
Check minimum brake disc thickness:
Position special tool 34 1 280 at three measuring points in area (1) and measure.
Compare measuring result and lowest value with setpoint value.
If the brake discs are replaced, you must also fit new brake pads.
Brake discs may only be replaced in pairs (on each axle).
Important!
New brake pads may only be fitted if the brake disc thickness is greater than the minimum brake disc thickness (MIN TH).
Release screws (1), remove brake caliper (2) with brake anchor plate (3) and tie back.
Installation note:
Tightening torque:
34 11 2AZ Type Thread Tightening specifications Value
2AZ
Brake anchor plate to swivel bearing
E81, E82, E87, E88, E90, E91, E92, E93, E84 M12x1.5
110 Nm
Check that brake hose is correctly fitted in holder.
image Important!
To release brake disc: Do not under any circumstances strike friction ring with a hammer or similar!
If necessary, carefully tap on base of brake disc chamber with a rubber mallet.
Clean contact surface of brake disc at wheel hub thoroughly and remove traces of corrosion.
Unevenness on contact surface may result in distortion of brake disc!
Release screw (1) and remove brake disc (2).
Installation note:
Replace screw.
Tightening torque:
34 11 1AZ Type Thread Tightening specifications Value
1AZ
Brake disc to wheel hub
Replace bolts
16 Nm
After installation:
Read and comply with notes on braking in new brake discs / brake pads.
Feb 12, 2021 at 5:14 AM
