(REPLACEMENT OF EXPANSION VALVE OF EVAPORATOR)
2008 HONDA CIVIC
65,000 MILES
DENPRION
The a/c compressor stoped cooling and after replacing it with a new one and regas it it was not cooling well.
The a/c compressor stops when THE ENGINE is running as you acclerate,
i need a Guide to replace the expansion valve.
May 7, 2013 at 1:12 PM
why do you think this is bad>>>> did you replace the dryer and have it evacuated???
what are the pressures as you need to stop guessing and find the failure
roy
May 7, 2013 at 5:23 PM
DENPRION
How do I replace the ac drier and have it evacuate.
I have not done it and I need to follow your professional guide and advice in order to have the best results.
May 8, 2013 at 12:46 AM
