Replacement battery cable assembly?
2003 KIA SORENTO
200,000 MILES
CYNLYNSMI
  • 6 POSTS
I have the vehicle listed above Lx. A local repair shop damaged my battery cable assembly at the starter connection by incorrectly probing the wires. Because of the age of the car, I am unable to find a replacement. I’ve even tried wrecking yards. The part I need is 372203E010(the cable that goes to the starter). There is another one that is identical under 372203E000 but carries a different battery voltage than mine, so it won’t work. I can’t afford another car as I am on Social Security. Also, I love my Kia and don’t want to give it up. It’s been an absolute trooper from day one. Any suggestions would be appreciated.
Sep 8, 2024 at 10:56 AM
I found one at Kia parts online. See pic 1 below. I know these have been discontinued, but they still have them. Here is the URL that I used. Click on this and it will take you to the site.
https://www.kiapartsonline.com/oem-parts/kia-cable-assembly-battery-372203e010
Let me know if this helps.
See pic below.
Sep 8, 2024 at 5:20 PM
CYNLYNSMI
  • 6 POSTS
I’ve contacted them and was told none are available. They order from Kia and have been discontinued.
Sep 8, 2024 at 6:30 PM
The one that you mentioned being exactly the same but carrying a different voltage, what voltage is it designed for? These vehicles all had a 12v system.
Sep 8, 2024 at 6:52 PM
CYNLYNSMI
  • 6 POSTS
My apologies. I miss quoted what the Kia dealer said. This was his explanation.
He says that these two are different. They are the physically the same but the wire rating for the battery size is different so they appear to be the same, but they are technically different.
Sep 8, 2024 at 8:54 PM
Is it possible that the one you can get is designed to process more power? In other words, it is a heavier duty wiring? If that is the case, it would be fine to use. However, you don't want to go to a smaller gauge wire that could overheat.
Sep 9, 2024 at 7:26 PM
CYNLYNSMI
  • 6 POSTS
This is what I got from the Kia dealer this morning.
They are physically the same part physically the same wire size but the fusible links which are incorporated into them are not the same. No, you cannot use one to the other. It would ruin the computer in the car.
Sep 10, 2024 at 10:48 AM
It would only hurt the computer if there was a short and the fusible link was too heavy gauge to fail. However, I don't know the specifics. If they are telling you that, I'm not sure what to say.
The only other thing is to check salvage yards. There are websites that will scan all salvage yards in the US. It's a thought.
Sep 10, 2024 at 6:23 PM
CYNLYNSMI
  • 6 POSTS
Do you know the salvage search site? I’ve tried the ones I know with no luck. I called a few here in Oregon and they said they usually cut those cables.
Sep 11, 2024 at 10:50 AM
I found one out of the country. See this link. You could order it there and it will ship within 6 days.
https://h2.ee/en/detail-search?articleNumber=372203E010
Check into that.
Also, if possible, send me the VIN number of the vehicle. I am trying to compare the two different part numbers you included, and they are both indicating the same type vehicle and engine size. Also, if you could let me know what was damaged on the original cable. If it was a fusible link, that should be able to be replaced/repaired.
See pics below.
Sep 11, 2024 at 6:14 PM
CYNLYNSMI
  • 6 POSTS
Technically it’s a 2002 but it’s listed in the US as an 03
No. KNDJC733935086037
The cable hasn’t been removed yet so I’m not sure of total damages. That probably won’t happen until Monday when I have some help.
Sep 11, 2024 at 6:29 PM
Based on the VIN number, you need the cable that is available, 372203E000. I attached the information below for you. Take a look at it and let me know if you have questions.
Note: The part number is tied directly to the VIN number. In this case, the part is still available.
See pic below.
Sep 11, 2024 at 7:00 PM
