Replacement alternator belt
1993 ACURA VIGOR
63,000 MILES • 2WD • MANUAL
SESAUNDERS12
The alternator belt broke and we are trying to get the new one on, but cannot figure out how to get the other belts out of the way.
Jul 10, 2018 at 5:15 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
To get the belts off that are in front of the alternator belt you must loosen the nut on the A/C idler pulley to loosen the set screw to loosen the belt. Loosen the nut on the power steering pump to loosen the set screw as well. I have attached a picture and circled in red what needs to be loosened. You will do same for the alternator. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Jul 10, 2018 at 10:37 PM
SESAUNDERS12
That is exactly what we needed! Thank you so much!
Jul 11, 2018 at 9:54 AM
DANNY L
  • 5,648 POSTS
Hello again.
You are welcome! And thanks again for using 2CarPros.
Danny-
Jul 11, 2018 at 4:52 PM
