Fuel tank pressure sensor location and replacement instructions needed
2004 FORD EXPEDITION
230,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
ANDRES210
I cannot find a single diagram on the fuel tank pressure sensor location to replace it.
Jul 11, 2021 at 2:57 PM
Good afternoon,
The sensor is in the Evap line above the fuel tank. The tank must be dropped to gain access to the sensor.
I attached the procedure and the part from rock auto for you below.
I also attached the procedure for dropping the tank for you.
Jul 11, 2021 at 3:37 PM
