Loss of power and heat stopped working after replacing water pump and fan clutch
1996 CHEVROLET ASTRO
120 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
JEFFREY ALAN JAMES
  • 6 POSTS
Loss of power when accelerating and loud roaring noise. The heat quit working. It all started after I replaced water pump and fan clutch.
Oct 25, 2019 at 1:09 PM
Good afternoon,
I would go over what you connected and disconnected and make sure you did not leave anything disconnected.
https://www.2carpros.com/articles/engine-has-low-power-output
Check the mass air flow sensor and be sure it is plugged and and tight and secure.
Is the check engine light on?
Oct 25, 2019 at 2:07 PM
