Replaced steering column, won't start now.
1997 BUICK RIVIERA
180,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
MANOMABRA
I have a 97 riv, the steering column had broken where it tilts so I located one at a junkyard,(was only at salvage yard for short time), I stripped it down and replaced ignition switch, turn signal switch and everything from broken column. I have to add that car has an aftermarket alarm and I did wire it back in. So I got it all put back together, turned key forward, everything works! Next I tried to start the car and nothing, again all lights, radio, heater/ac etc work fine but starter did nothing. I tried cleaning the key and using the spare(have chip on key) and that is all I have tried so far. I thought I would ask the professionals now and I'm going to troubleshoot the car now while I wait for an answer. Thank you verymuch
Apr 1, 2014 at 9:15 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like it could be the aftermarket alarm try just running the yellow wire from the ignition switch not thur the alarm just reconnect it to the original cars wiring with a butt connector. See if it starts then?
Apr 2, 2014 at 6:25 AM
NOSUITS1
I have the same exact problem with my 97 Riviera. I replaced the steering column but kept the upper bracket (it was the lower bracket that broke) which containes the original ignition cylinder and chip key, thus all electrical / harness connections are the same. As with previous post, all electrical systems work: light, windows, AC, wipers, etc, but the car now won't start, won't crank. Anyone have any ideas?
Jul 15, 2017 at 6:15 PM
