Replaced starter, no changes whatsoever, still will not start
2006 CHEVROLET HHR
189,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MEBAR2M
At first, my car was taking a second and had a delay with starting. Lasted a couple days. I was in denial but kept going. Went to leave work and it wouldn't turn over. Tapped the starter and it turned right over. Next day I found a ride to get the new starter and after a horrendously difficult time, got the starter replaced. There was no change. It wasn't even trying to turn over. Called my dad to check my work, he verified I did it correctly and said it could be the battery, despite all lights and every thing coming on. Every thing fine except it not wanting to crank over. Took the battery and old starter to O'Reilly and they verified the starter was bad, battery was at 110%... I'm at a loss. I've checked relays and such, but I'm no pro. Any ideas?! Thanks in advance!
Jan 16, 2020 at 5:29 AM
Good afternoon,
I attached a wiring diagram for you to view. Check the crank fuse for power in the start position to see if you are getting a signal from the ignition switch.
Jan 16, 2020 at 9:41 AM
SCGRANTURISMO
  • 4,897 POSTS
In the diagrams down below I have included a staring circuit wiring diagram for your vehicle. Please check the wire going from the battery to the starter. Please make sure that that the connections are clean, tight, corrosion free, and making good metal to metal contact. Check the electrical connector at the starter as well. Finally inspect the ground strap from the engine block to the body frame. In the diagrams below I have also included a guide on known faults in an automotive electrical circuit as well. If everything checks out, then the starter is probably going to be bad right out of the box, which wouldn't be the first time, and unfortunately, not the last time that this has happened. Please let us know what you find out.
Thanks,
Alex
2CarPros
This guide can help. does it starter in neutral?
https://www.2carpros.com/articles/starter-not-working-repair
Please let us know.
Jan 16, 2020 at 8:59 PM
MEBAR2M
I just went out to try getting it going in neutral with no luck. The lights and stuff still work so I'm assuming battery is still fine, however when I go to turn it over, it makes a click sound and nothing happens. I just hope the engine isn't locked up. I was kind of wondering if it might not have anything to do with the security system. My key-less entry fob kicked the bucket awhile back and I get honked at every time I unlock and open the door manually. Is there a safety setting flaw with the security system?
Jan 17, 2020 at 6:09 AM
Can you give me the battery voltage on the battery?
Jan 17, 2020 at 6:55 AM
MEBAR2M
I believe it is 12V. However, the day I replaced the starter with a new one with no change, the battery charge was at 110%.
Jan 17, 2020 at 6:59 AM
The battery needs to be 12.5. If it is 12 the battery is almost dead.
Jan 17, 2020 at 7:19 AM
Is the security light flashing when you try to crank it over? Also let's check the crank relay under the hood. here is a guide and the relay location below:
and
https://www.2carpros.com/articles/how-to-reset-a-security-system
Check out the diagrams (below). Please let us know what you find.
Jan 18, 2020 at 10:24 AM
