Replaced leaking engine oil cooler, now oil and temperature lights on
1998 AUDI A4
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
A4TROUBLES98
MEMBER
1 POST
FOLLOW
Oil cooler had a crack, replaced it. Did an oil change. The car is sputtering, temperature and oil lights are on. Afraid to drive it.
Feb 22, 2019 at 6:38 AM
CERTIFIED EXPERT
I sounds like you disconnect a ground wire when you were doing the repair. can you please use a flashlight and check all engine grounds? Also, see if you bummed a wiring connector off somewhere and we should run the codes. Here is a guide to help us get started:
