replaced ignition switch with a new key
2002 LAND ROVER FREELANDER
180,000 MILES • 2.8L • V6 • 4WD • AUTOMATIC
MLBRIDGE54
Hello, recently I replaced the ignition switch, ignition barrel and have a new key as well. I took the key chip out of the old key and placed it in the new key . When I try to start it it does nothing. Everything else seems to come on when I turn the key but nothing as far as the engine no sound what so ever. Please help
May 31, 2017 at 9:02 PM
HMAC300
  • 48,601 POSTS
you have to have a mechanic reprogram the switch/key to the car as anti theft is engaged is the reason car will not start.
Jun 1, 2017 at 6:44 AM
MLBRIDGE54
Thank you for the information. Can I do this with out a key reprogramming machine?
Jun 1, 2017 at 9:32 AM
HMAC300
  • 48,601 POSTS
any mechanic at a garage with a pro scanner can do it. when you replace the switch the transponder in that key is the one that should be used not the old one. if it still will not start it still need reprogramming.
Jun 1, 2017 at 11:58 AM
