replaced heater core now gauges dont work correctly
1999 JEEP CHEROKEE
264,000 MILES
K07032004
engine runs fine but gauges come on for a second the tach dies after a few seconds and the other gauges don't read correctly when I turn the light on all the gauges die and the turn signal indicator lights both come on and stay on I have checked connections and fuses and still no luck
Jun 9, 2013 at 12:38 PM
CJ MEDEVAC
  • 11,004 POSTS
IT RUNS?
HAVE YOU HAD TO JUMP START IT?..........RECENTLY?
THE MEDIC
Jun 9, 2013 at 6:37 PM
K07032004
Yes it runs
No have not had to jump start it at all
Jun 9, 2013 at 7:45 PM
CJ MEDEVAC
  • 11,004 POSTS
JUST FOR GIGGLES, HAVE YOUR BATTERY TESTED AT A POPULAR AUTO PARTS STORE.....THIS IS USUALLY A FREE SERVICE........NOTHING LIKE SOMETHING TOTALLY UNRELATED MESSING YOU UP
......SOMETIMES, JUST DISCONNECTING IT MIGHT RESET STUFF
YOU MAY NOT HAVE GOT A GROUND BACK IN PLACE, OR TIGHT
WITHOUT CORRECT NOMENCLATURE AND ENGINE SIZE.......I JUST GUESSED, AND GRABBED THIS DIAGRAM OUT OF "MITCHELL I"
THIS ONE IS "INSTRUMENTS" FOR A '99 CHEROKEE LIMITED (CORRECT ME IF I GUESSED WRONG....I HAD 4 CHOICES ON MODEL) SOMETIMES THE "COMMON STUFF" DIAGRAMS ARE THE SAME DIAGRAM AS FOR THE OTHER MODELS
LOOK FOR THE "GROUNDS" IN THE DIAGRAM.......NORMALLY A LOCATION IS GIVEN FOR THEM
LEMME KNOW THE DEAL
I WORK......WILL GET BACK WITH YOU WHEN I GET BACK ON....IF YOU SHOULD RESPOND
THE MEDIC
Jun 9, 2013 at 9:01 PM
