Will not start after replacing the crankshaft position sensor
2007 TOYOTA TUNDRA
136,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MIKEH12
I replaced the crankshaft position sensor because I got a code saying it was bad and had trouble starting a few times but after I replaced the sensor it will not start at all. I did disconnect the negative battery terminal before I replace the sensor. would that have caused a problem?
Jun 14, 2020 at 11:53 AM
Good afternoon,
What was the code that was set? It is rare that a code identifies a bad part, it identifies a failed system.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
When you crank the engine, does the tachometer move up a little and show RPM? That will tell me if the sensor is sending a signal to the ECM.
Jun 14, 2020 at 1:39 PM
MIKEH12
P0335 was the code. I took out the new sensor and put back in the old one and now it will crank, but is still giving the same code.
Jun 14, 2020 at 2:23 PM
Okay, if it runs with the old sensor, then you have a bad new sensor.
I would get an OEM sensor as it may not be up to quality at all. Very common.
I attached possibilities for you.
Jun 14, 2020 at 2:34 PM
MIKEH12
Thanks for the quick response.
Jun 14, 2020 at 2:38 PM
You are welcome.
always glad to help.
Jun 14, 2020 at 2:43 PM
