There was a short in turn signal switch. Was not a replaceable arm had to replace entire combination switch with a new clock spring included. There was no air bag light on previously. Brought a brand new combo switch with clock spring from local toyota dealer, OEM part. Set clock spring by directions. Hooked everything back together air bag light on dash is staying on. Horn and cruise works. Pulled code 14 (bad clock spring or air bag module) but I'm having trouble accepting that - there was nothing wrong before, and the clock spring is powering horn and cruise fine and is brand new. Reset codes, light came back on same code. I have read about manual ways to reset this dash light with grounding certain box terminals. Toyota dealer wont help, and says part is not returnable since its electrical and been installed. Suggestions?
Feb 17, 2017 at 4:18 PM
