Replaced battery and won't start?
2011 KIA SORENTO
162,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
KEVDOGG1
Car just clicked replaced battery hooked up cables and horn started honking and lights started flashing. Put the key in the door unlocked it got in put the key in the ignition turned to run didn't stop alarm. Tried to start and nothing. Tried the lock unlock with the remote and nothing.
Jan 25, 2026 at 10:41 AM
KRAKENAUTO
  • 39 POSTS
You have likely tripped the immobilizer. Ensure your terminals are tight and not corroded. Do you notice if there's a security light flashing on the dashboard?
Jan 26, 2026 at 8:00 AM
KEVDOGG1
No security light flashing but the dash is flashing horn is honking and hazard lights are flashing. Battery cables are tight and clean.
Jan 27, 2026 at 7:17 AM
Okay, disconnect the battery again and do a hard reboot for the system, this video will show you how.
https://www.youtube.com/watch?v=INiDRO5A5MY
Jan 28, 2026 at 8:56 AM
KEVDOGG1
I have tried that several times with no luck.
Jan 28, 2026 at 9:17 AM
Okay try this
Driver Door ONLY (not passenger):
1. Close all doors
2. Insert key in driver door lock
3. Turn key to UNLOCK position
4. Hold it there for 30 seconds
5. Return to center
6. Lock door
7. Unlock again
8. Try starting
This sends a “valid owner” signal directly to the Body Control Module (BCM)
Let me know what happens.
Jan 28, 2026 at 9:41 AM
