Okay. That makes a little more sense as to why the code changed after you put the used on in it. That controller must have had that issue and when installed on your truck it fixed the first codes but gave you knew ones. Unfortunately that is common on used parts.
If there is an issue with the controller just reprogramming it will not fix it unless they are putting in software specifically to correct that issue, which is unlikely in this case.
Based on this information I would expect the new part to correct the issue.
Jul 7, 2019 at 8:52 AM
