Replaced A/C Compressor, condenser, drier and now the A/C clutch stays engaged after turning it off?
2004 BMW Z4
197,000 MILES • 3.0L • 6 CYL • 2WD • MANUAL
K BOOTHE
When I removed the old compressor, I found that the power wire going to the AC clutch's insulation had melted off. I replaced the above items, vacuumed down and recharged the system. A/C working except that when I turn A/C off on the switch, the A/C Clutch stays engaged and turning.
Aug 17, 2022 at 5:10 AM
Yep, this happens when HVAC controller goes out. To be sure we should do a CAN scan. You can get a CAN scanner from Amazon for about $30.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is a scanner link:
https://amzn.to/3o41KcZ
If the scan says it is bad, install a new unit. This car has an internal compressor valve. How can you tell if the compressor is engaged if there is no clutch?
Aug 17, 2022 at 12:49 PM
