This car has the longest procedure for replacing the gear range sensor I have ever seen. You must get all of the steps done correctly or the transmission will not work. Here is how to do the job, I would go over this to see if can remember if anything was not done correctly, did the transmission work before? Why did you replace the gear range sensor? Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Oct 7, 2024 at 9:42 AM
