Replace water pump
2001 FORD COBRA
155,000 MILES • 4.6L • V8 • RWD • MANUAL
NOTAPROMIKE2
  • 32 POSTS
I would like detailed instructions for replacing the water pump (leaking). I have been told I need to be careful when refilling the cooling system so as not to leave any air trapped. How do I do that? Also, do I need to use any special type anti-freeze? Thank you. Mike
Feb 3, 2017 at 10:14 AM
HMAC300
  • 48,601 POSTS
see pictures for removal and install plus bleeding. pictured is Cobra with cross pipe. use what is on label under hood or check at auto parts if it only shows a Ford spec for coolant use compatible.
Feb 3, 2017 at 12:12 PM
NOTAPROMIKE2
  • 32 POSTS
Never did say thank you but I am now. Been sick. Starting job today. How does the water pump pulley come off? Do I need a puller? Thanks. Mike
Feb 10, 2017 at 10:14 AM
HMAC300
  • 48,601 POSTS
try spraying some penetrating oil around the pulley and tapping with a small hammer it may come off otherwise you'll need a puller to get it off but it should come off without it.
Feb 10, 2017 at 12:13 PM
NOTAPROMIKE2
  • 32 POSTS
Came off. Thank you again
Feb 10, 2017 at 1:09 PM
Hey Mike,
Here is a guide and video to give you an idea on what you are in for when doing the job
https://www.2carpros.com/articles/water-pump-replacement
Please let us know happens so it will help others.
Best, Ken
Feb 13, 2017 at 11:09 AM
