Speed sensor location for replacement
2008 INFINITI EX35
150,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
TALKTALKCAR
  • 6 POSTS
Where is the transmission speed sensor? Need to find it and replace. Thanks
May 23, 2020 at 2:06 PM
Good evening,
It is inside the transmission and is tricky to do. I attached pictures and the procedure for you to follow.
Why are you replacing it?
REVOLUTION SENSOR
TM-264 Exploded View
2WD: Removal and Installation
REMOVAL
1. Disconnect the battery cable from the negative terminal.
2. Drain ATF through drain plug.
3. Remove exhaust front tube and center muffler with power tool.
4. Remove heat insulator.
5. Remove rear propeller shaft.
6. Remove control rod.
7. Remove exhaust mounting bracket.
8. Disconnect heated oxygen sensor 2 harness connectors (A).
: Vehicle front
: Bolt
9. Remove heated oxygen sensor 2 harness (B) from clips (1).
10. Remove bracket (2) from transmission assembly
11. Remove clips (1).
3: Drain plug
: Vehicle front
: Oil pan mounting bolt
12. Remove oil pan (2) and oil pan gasket.
13. Support A/T assembly with a transmission jack.
CAUTION: When setting transmission jack, place wooden blocks to prevent from damaging control valve with TCM and transmission case.
14. Remove rear engine mounting member with power tool.
15. Remove engine mounting insulator (rear).
16. Remove tightening bolts for rear extension assembly and transmission case.
1: Self-sealing bolt
A: Bolt
17. Tap rear extension assembly with a soft hammer (A).
18. Remove rear extension assembly (with needle bearing) from transmission case.
19. Disconnect revolution sensor connector (A).
CAUTION: Be careful not to damage connector
20. Disengage terminal clip (
May 23, 2020 at 5:15 PM
