Hello all,
My bushings for the sway bar and sway bar links are bad as well as the lower control arm bushings. I am slowly working on replacing these and i a wondering if there is a correct order i should replace these? Should i replace the bushings for the control arms first because the control arm supports the sway bar or the other way around or does it not matter just replace them in a timely manner? your input is greatly appreciated, Thanks!
Sep 10, 2016 at 7:49 AM
