replace sway bar bushings or control arm bushing first
2002 DODGE NEON
180,000 MILES
BREWWRIAH
Hello all,
My bushings for the sway bar and sway bar links are bad as well as the lower control arm bushings. I am slowly working on replacing these and i a wondering if there is a correct order i should replace these? Should i replace the bushings for the control arms first because the control arm supports the sway bar or the other way around or does it not matter just replace them in a timely manner? your input is greatly appreciated, Thanks!
Sep 10, 2016 at 7:49 AM
SATURNTECH9
  • 30,869 POSTS
I would do the control arm bushings first those will take the longest. Does not really matter which order you do them in though.
Sep 10, 2016 at 9:16 PM
