Codes P0521, P0340, P0341, and P0016, after replacing the rear main seal?
2006 GMC ENVOY
199,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
SAELI SAELI
I replaced the rear main seal on my vehicle listed above xl Denali and now I have codes, P0521, P0340, P0341, and P0016.
Apr 24, 2025 at 7:04 PM
So all of these codes can be because the engine oil is dirty or low. I would make sure the engine oil is in good shape and then clear the codes and drive it. Can I ask if you are hearing any noises from the engine at idle?
P0521 - Engine Oil Pressure Sensor/Switch Range/Performance
P0340 - Camshaft Position Sensor “A” Circuit Bank 1
P0341 - Camshaft Position Sensor Range/Performance
P0016 - Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
Please upload pictures or videos in your response.
Apr 25, 2025 at 10:32 AM
