Front wiper motor replacement
2009 VOLVO XC90
88,000 MILES • 0.6L • V6 • 4WD • AUTOMATIC
LOUIS OLWANA
Front wiper does not work. Need instructions on how to replace wiper motor.
Jan 7, 2018 at 12:35 PM
STEVE W.
  • 15,113 POSTS
Have you checked the fuses and switch to be sure they are not the problem? Here are the wiper motor replacement instructions in the diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jan 7, 2018 at 2:33 PM
RTELLIER
how to replace rear wiper motor volvo xc90
Jul 28, 2020 at 12:01 PM (Merged)
JIS001
  • 3,412 POSTS
You need to remove the rear panel. Remove the light and there will be a screw and one I believe behinde the handle as well. Once you remove the 2 screws the rest will be plastic clips holding the panel. You would need to pry the panel out nees the clips. You may also need to remove the upper trim piece as well to remove the panel. Let me know if the info helped you?
