Replace front rotor on a Ford Falcon BA XR6
2003 FORD FALCON
180,000 MILES
LEOPARD
Please can you advise me what size socket spanner or tube spanner is used to remove the rotor from the main shaft.on the front wheels of a 2003 Ford Falcon BA XR6. I have all the necessary tools but I'm not sure if I have the necessary size socket spanner for removing the main nut on the rotor.
Jul 3, 2013 at 9:46 PM
MHPAUTOS
  • 31,937 POSTS
You do not have to remove the bearing hub to take off the rotor, with the caliper removed it will knock off, it will just be stuck on the wheel studs, a good belt with a soft hammer and it will pop off.
Jul 4, 2013 at 4:26 AM
LEOPARD
Thank you very much for you prompt reply.
Regards
Ed.
Jul 4, 2013 at 8:45 AM
MHPAUTOS
  • 31,937 POSTS
your welcome!
Jul 9, 2013 at 4:01 AM
