ABS speed sensor replacement (was accidentally broken when other work was done on this wheel)
Sep 2, 2015 at 12:14 PM
MHPAUTOS
CERTIFIED EXPERT
The sensor should just be a single wire connection and the sensor will be attached by a 8 or 10mm bolt undo and pull sensor out, I will find a manual and double check that this is correct for your car, most ABS sensors are like this.
