Its really not a very difficult job. Typically you have to remove the seat. There is usually 4 nuts or bolts that hold the seat down. If you have power seats then you will have to just disconnect the connectors underneath the seat. If you have any YELLOW connectors (airbag) under your seat. Do not disconnect. You must first disconnect the battery and wait about 5 minutes or so then you can disconnect the airbag connector if you have one. Then you have access to the receiver part of the seat belt. There is usually a connector running to it that senses if you have your self belt on or not. Should just been nut or bolt holding it in.
Dec 5, 2015 at 9:46 AM
