I need to replace the crankshaft seal, but how do I take the bolt off and the pulleys off?
Image (Click to enlarge)
Aug 6, 2018 at 5:37 PM
CERTIFIED EXPERT
Good evening.
The bolt is very tight. If you have an air gun, that will release the bolt. Otherwise, you need the tool I attached in the photo.
Once you remove the bolt, the balancer should just slide off. When you reattach it, the torque spec is listed in the other picture I attached.
Aug 6, 2018 at 6:26 PM
FIREWOODFLARES
MEMBER
After two days of trying to figure it out, you sent exactly what I needed. That is so cool, Thank you so much!
Aug 7, 2018 at 2:43 PM
CERTIFIED EXPERT
You are welcome. Glad to help.
Feel free to ask any follow-up questions.
Aug 7, 2018 at 2:46 PM
FIREWOODFLARES
MEMBER
How do I take the pulley assembly off to get to the lower crankseal cover?
Aug 8, 2018 at 5:01 PM
CERTIFIED EXPERT
Did you remove the center bolt from the pulley?
If you did, it should just slide off. Uou may need a hammer to hit the back of the pulley to help it off.
Aug 8, 2018 at 5:06 PM
FIREWOODFLARES
MEMBER
Maybe I did not explain it right. It is the whole assembly I need to take off. Here is a picture.
Aug 8, 2018 at 5:34 PM
FIREWOODFLARES
MEMBER
Here is the picture:
Aug 8, 2018 at 5:48 PM
CERTIFIED EXPERT
Cannot see down to the balancer. Can you take a better picture?
Aug 9, 2018 at 3:10 AM
FIREWOODFLARES
MEMBER
The balancer has been removed. Need to know how to take off all that you can see in picture - everything underneath where the thermostat goes. The metal piece that holds all the pulleys on.
