Engine intermittently shuts off
1991 SAAB 9000
200,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
JVRSAABNUT
Engine stalls random, then restarts after a few minutes. replace crank position sensor.
Jun 18, 2019 at 6:23 AM
Welcome to 2CarPros.
The first thing I need you to do is check for diagnostic trouble codes. This has an OBD1 system and you can check it at home. All that is needed is a short jumper wire or even a paper clip.
Follow the directions in this link and let me know the results.
https://www.2carpros.com/articles/saab-code-retrieval-procedure-and-definition-table-1988-1992
I will watch for your reply.
Jun 19, 2019 at 8:01 PM
