Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Mercury
Marquis
Exterior Light
Brake Light
REPLACE/REMOVE
Replace break light bulb.
2007 MERCURY MARQUIS
63,000 MILES • 4.1L • V8 • 2WD • AUTOMATIC
HARRY DAY
MEMBER
1 POST
FOLLOW
Driver side break light is out.
Feb 10, 2016 at 6:49 PM
HMAC300
CERTIFIED EXPERT
assuming you have checked the bulb check to see if you are getting power at the lt. grn /org wire if you are then it may be a bad socket or ground if no power see if it is coming from multi function switch on steering wheel.
Feb 11, 2016 at 6:28 AM
