Hi, I recently had my car service and the mechanic pointed out work that needed doing to it hopefully roadside by me
O/S Front bottom ball joint has play.
Front track rod ends perished.
O/S steering gaiter torn.
(I imagine this is all on the same side).
Gearbox mounts worn.
Front diff mount perished/worn.
would these parts cover me?
http://www.milneroffroad.com/mitsubishi-japanese-import/delica/pe8w-2-8td-same-as-pdpf8w-82004-import/pe8w-steering/pe8w-steering-track-tie-rod-end-kit-rh-or-lh
http://www.milneroffroad.com/mitsubishi-japanese-import/delica/pe8w-2-8td-same-as-pdpf8w-82004-import/pe8w-suspension/pe8w-suspension-ball-joint-front-lower-rh
http://www.ebay.co.uk/itm/MITSUBISHI-DELICA-L400-POWER-STEERING-RACK-BOOT-GAITER-/121734647773
http://www.japanese4x4parts.co.uk/mitsubishi-delica-28td-pe8wpd8wpf8w-import---differential-diff-mount-bush-kit-13278-p.asp
http://www.ebay.co.uk/itm/FOR-MITSUBISHI-DELICA-L400-SPACE-GEAR-94-04-REAR-GEARBOX-MOUNT-MOUNTING-x1-/171069670576
Apr 7, 2017 at 10:47 AM
