Replacing camshaft position sensor
2002 CHEVROLET IMPALA
125,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
CHEVYWTF2002
  • 4 POSTS
I'm trying to replace the camshaft position sensor, but it seems to be between the engine block and fuel injection system. Help!
Jul 6, 2022 at 7:26 PM
CHEVYWTF2002
  • 4 POSTS
Here's what it looks like:
Jul 6, 2022 at 7:29 PM
SQM
  • 6,383 POSTS
The Cam position sensor is located on the top part of the engine.
The replacement procedure does not call for removal of any other components.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
See attached for the replacement procedure.
Let me know of any questions.
Thank you.
Jul 6, 2022 at 10:32 PM
CHEVYWTF2002
  • 4 POSTS
Did you see the attached photo that shows it between the fuel injector and the engine block?
Jul 6, 2022 at 10:44 PM
Yes, but that is not the camshaft sensor, if you look at the diagrams Sean gave you can see where the sensor is.
Jul 9, 2022 at 12:45 PM
CHEVYWTF2002
  • 4 POSTS
It is the camshaft sensor. I had to remove the upper intake manifold to get to it because the previous owner must have put everything together wrong. It's fixed.
Jul 9, 2022 at 12:48 PM
In the picture there are two wires going to different places, glad you got it fixed.
Jul 10, 2022 at 12:44 PM
