2004 Renault Scenic engine mgmnt light
2004 RENAULT SCENIC
28,000 MILES • 4 CYL • FWD • MANUAL
DAVEY ROONEY
the dreaded light is on,and the message says.check emissions what does it mean and do i need to take out a mortgage to get it fixed
Mar 30, 2009 at 6:23 AM
DAVE H
  • 13,384 POSTS
If the vehicle is running as normal .. the light could be on as it has picked up on an intermittent fault .. you need to have the vehicle plugged into a diagnostic computer to locate the exact cause ..it could be something as simple as 1 misfire at some stage and the light just needs turning off to clear the fault code from the cars computer memory .. hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_414.png
Apr 1, 2009 at 5:31 AM
DAVEY ROONEY
tested at garage.02 sensor needed thanks for replying
Apr 1, 2009 at 5:35 AM
