2004 Renault Scenic
2004 RENAULT SCENIC
66,000 MILES • 4 CYL • 2WD • MANUAL
CHATTERS
had heater fan repaired under warrantee some time ago.but realised 2 days later air con didnt work any more.they say they removed most of the dash to get to the heater fan, removed debrie causing noise...since then there is no response from the air con switch doesnt even get the little red light on when pressed.i was wondering if they have left a plug undone or broken something while under the dash like the rheostat , i have been told that this item is by or attached to the fan unit itself they are trying to say that it couldnt have been working before this ,but i know it was in perfect order its like its none existant i have checked every fuse in the car including main fuses under the fuse box in the engine bay,glove box and,underthe passenger seat,,any ideas would help
Mar 13, 2009 at 12:13 PM
DAVE H
  • 13,384 POSTS
chances are if it was working before they "fixed" it ...then it is something they have left off .. you really need them to look into why it is not working now !!most systems on this model are controlled by the computer module .. have them plug it into their diagnostic scanner .. They relly should be helping you out here, as they did the work !! just remember if they do look into it for you .. they will never admit it is something they did not do correctly .. We do not have any tech spec's for this vehicle as it was nor released in the USA .. your local library or autoparts store should be able to supply a repair manual ..you will need to look for any plugs not connected or broken wires etc. .. hope this helps .. let me know
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_231.png
Mar 13, 2009 at 6:34 PM
