2000 Renault Scenic transmission diagnostic code
2000 RENAULT SCENIC
ABING69
Transmission problem
2000 Renault Scenic All Wheel Drive Automatic 82000 miles
hi i ve got a renault scenic with no forward gears just reverse ive had a diagnostic code done which is 08706 and cant find the cause from the code have scanned the internet to no avail pls help as costing me a fortune so far
Sep 7, 2009 at 5:22 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Please re check this code as it is an unknown code.
mark (mhpautos)
Sep 8, 2009 at 1:50 AM
DAVE H
  • 13,384 POSTS
Hope you don't mind me adding 2 pennies worth The code you are supplying us is probably the renault code for the fault, (renault do not release these codes) it will interchange with a "P" code on the standardised international/european system, the "P" code is what we need (ie. P1706) this will give us the reason for the fault, or you could ring a renault dealer for an explanation of the fault code ? ... most good repair centre's will be able to plug the car into a diagnostic computer to retrieve the "P" code, repost with the code for more information or repost with a detailed explanation of the fault !! Dave H
https://www.2carpros.com/forum/automotive_pictures/266999_smiley3_7.png
Sep 8, 2009 at 4:10 AM
