2000 Renault Scenic Gears
2000 RENAULT SCENIC
AESCALAPIUS
Transmission problem
2000 Renault Scenic Two Wheel Drive Automatic 45000 miles
1. Car often takes a long time to shift up but will always eventually do so.
2. Recently, after it stops at the traffic lights, nothing happens when you depress the accelerator to go, then the gear would suddenly engage with a judder. Once this starts, the "juddering" will increase in frequency. This occurs only after the car has warmed up and will behave normally again after the engine cools down.
Feb 26, 2009 at 1:28 PM
DAVE H
  • 13,384 POSTS
have the car plugged into a diagnostic scanner to locate the actual fault !
Feb 26, 2009 at 10:19 PM
