1999 Renault Scenic clutch change
1999 RENAULT SCENIC
CHAMBO2009
Transmission problem
1999 Renault Scenic 4 cyl Front Wheel Drive Manual
i need to change the clutch on my renault megane scenic 16 16v do i have to remove engine or do i need to drop all the the sub frame under the car to get the gear box out the way to change the clutch im a bit ov a mechnic but this looks tricky ive already removed the two drive shaftes out ov the way can some one help as im loosing the plot thanks regards nathan
Apr 16, 2009 at 1:11 PM
DAVE H
  • 13,384 POSTS
you can remove the subframe and then just the gearbox with the engine supported from above ... you will need an engine support frame to hold the engine (under the bonnet) .. otherwise the whole lot has to be removed ... hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_509.png
Apr 16, 2009 at 7:55 PM
