1998 Renault Scenic ignition system
1998 RENAULT SCENIC
230,000 MILES • 4 CYL • 2WD • MANUAL
HENRY BARNARD
my renault scenic misses intermittently. i have checked all obvious possibilities, such as renew plugs, renew plug wires (leads), checked pressurre test, (ok), i suspect some ignition sensor or other ignition problem, i need some advice where to look or a wiring diagram (and perhaps a schematic diagram) showing operation of system, and how all the sensors work. indication of where on or in the car to look for the various parts would be tremendously helpful.
thanks to anyone that can help.
Henry.
Apr 28, 2010 at 10:06 AM
DAVE H
  • 13,384 POSTS
check/clean or replace the crankshaft position sensor .. check coils are good .. check/clean injectors
Apr 30, 2010 at 3:40 AM
