washer fluid (wiper_switch) problem
RENAULT
DMHERLIN
Hi.. hope you can help me.
Renault Clio Bebop 1994.
The washer fluid does not spray when i pull the switch which is is on the same wiper switch as the wipers , (the wipers work fine).
I got a new wiper switch from renault, it did not work either.
However when i have removed the switch i end up with the white box where the leads/wires goes into, i took a piece of wire and prodded the different inputs until i got to the combination of the washer fluid, and it WORKED. however when putting the actual wiper switch on it doesnt work..any ideas, i was thinking to cut into the leads with 2 wires and put a button on dashboard for the washer just to get it through MOT..any ideas what it could be or how i can fix it ?,,any help appriciated.
Daniel
Sep 20, 2007 at 11:11 AM
DAVE H
  • 13,384 POSTS
Check you have not blown fuse when poking about with wire ... other than that i can only think you bought a duffer switch ??
Nov 8, 2008 at 2:32 PM
