2005 Renault Megane Engine overheating
2005 RENAULT MEGANE
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
DPRUDENT
My car is over heating occassionally. When the atmosphere temperature is above 35 degrees Celcius (I live in the Caribbean), the a/c stops blowing cold air and the car starts to over heat when at stand still. Once you start driving the a/c will start blowing cold air again and the engine temperature returns to normal. Also when the car in over heating, if you take off the a/c, the engine temperature cools down to normal as well.
What is causing this situation?
Feb 11, 2010 at 7:57 AM
DAVE H
  • 13,384 POSTS
start by checking the coolant levels are correct ... repalce thermostat and flush cooling system
Feb 16, 2010 at 3:28 AM
ADIO OLUSEGUN DAVID
My scenic always overheating whenever my ac is on, what could be the remedy?
Dec 9, 2018 at 10:26 AM
DANNY L
  • 5,648 POSTS
Hello, Im Danny
Unfortunately you responded to a question that is years old.You need to start a new question and include you cars information.Hope this helps and thanks for using 2CarPros.Here is the link.
Danny-
Dec 9, 2018 at 5:47 PM
